RE: Thunder Tiger MT4 G3 (formerly AE SC10 RS, HPI Blitz, or something else?)
Most people will not charge their lipos above 1c, as it can damage the lipo or worse,
Lets say that if you have a
3800mah lipo to charge that @1c you would charge it at 3.8A
4000mah = 4.0A
5000mah = 5.0A
And so on,
The 50w charger you mentioned earlier will charge at a max of 5.0A,
Which will be fine for upto 1 lipo @ 5000mah,
it will not charge 2 5000 lipos any faster on a parallel Charging board as its maxxed out at 5A
To benefit from charging two 5000 lipo on a parallel charging board you would need 10A charge rate,
This gives 5.0A to each pack, this then allows charging 2 packs at the same time, saving time.
