RCU Forums - View Single Post - Kangke Waco Biplane
Old 12-16-2012, 05:17 PM
  #620
railfly
Default RE: Kangke Waco Biplane
I sent the measurements from the original to tnt they provide a schematic you can fill in with the measurements. The plane flies great will do all the imac and other maneuvers a little short on power for 3D. Do not omit the strengthening of the nose should have had 1/4 inch plywood instead of 1/8 for the stringers running through the firewall to the first former. Even that is not enough considering the leverage forward of the firewall with the tork of the engine. $275 is a fair price considering they want over $500.00 for a new one. You won't have any problem with the nose as long as you don't make hard contact with the ground with the nose,like tearing off the landing gear. Ive torn the nose off and never broke the prop image that.
