Appliying rudder into the wind is simply to hold position and has little to do with attitude. Just before touch down the rudder is nuetralized as to not rip the gear off the airplane. Simple as that. Bob and I have done literally thousands of landings that way
I'm puzzled. If the wings are level and the nose is pointed into the wind, you are just crabbing, which as Harry and I have been saying is the usual way to handle a crosswind. But if you are actually
holding rudder into the wind, with the wings level, you would be constantly making a skidding turn toward the direction of the wind. Why would you want to do that?
Bob says he counteracts the effect of holding rudder into the wind by holding the wing away from the wind down. So he's slipping, but with the low wing on the downwind side, so that the plane's sideways motion is away from the wind. Why do that?
I don't see how having extra power and lower wing loading justifies making skidding turns the norm. It's true, as Major T says, that different planes handle differently. In some you lead the turn with rudder, in others with aileron. I've never heard of one where skidding is routine, though. The one difference between models and full scale that makes a difference here is that models don't have passengers who would likely become uncomfortable in skidding turns.
