RCU Forums - View Single Post - *Servo Operated Choke With DX7*
Old 01-09-2013, 08:05 PM
chuckk2
Default RE: *Servo Operated Choke With DX7*
A generic digital meter (DVM) with DC current measurement should work. You would have to make or modify a servo extension lead by cutting the red wire and stripping the cut ends.
The DVM's current measurement terminals/leads would be connected to the stripped ends of the red wire. Expect current measurements between 100 milliamps or less to a maximum of about 5 amps.
The meters current measurement functions may use the common terminal, and a special current measurement terminal.
