Overview
The Spektrum™ SPMA9584 Aircraft Telemetry JetCat sensor is compatible with the Spektrum TM1000 Telemetry Module X-BUS expansion port.
Specifications
Type: SPMA9584 Aircraft Telemetry JetCat Sensor
Measures: Throttle position, pack voltage, pump voltage, EGT, RPM, OFF condition
Operational Voltage: 3.5 to 9.6 volts
Dimensions: 28mm x 16mm x 7mm
Weight: Circuit board - 4 gram
Calibration: No user calibration required
Units: Metric or English units
Includes:
Sensor
6-inch X-BUS extension
Key Features
Displays key turbine data including Turbine RPM, Turbine temperature, Throttle %, ECU Pack and Pump Voltage, and ECU status
Easy installation and use. Simply Plug in Jetcat sensor to ECU and TR1000 telemetry module
User defined vibration and/or tone warnings alerts users if an issue with the turbine occurs in flight
Source:
http://www.spektrumrc.com/Products/D...rodID=SPMA9584
I picked one of these beauties up the other week...
Very small and very light
This is what comes in the packet
I found it worked well connecting to both my DX18 and iPad w STi
A couple more pics and description here:
http://www.rcparkflying.com/radio-co...ensor-spma9584
Anyone else using the JetCat sensor and how do you find it?
