RE: Skymaster Mig-29 OVT Single with S-bus Build
Putting these nozzles together was like trying to teach a monkey how to F a football... And I work with small tools in tight places all day. The last part of the pipe fits into the metal ring ...kind of. I had to grind the hell out of the ring to make them fit. Hopefully the ones Tam made for me are a few tenths narrower. The last former in the fuse had to be cut to allow the rods to pass, same with the former in the nozzle part that attaches to the fuse. I haven't attached the final nozzles that go over the actual movable part. Tam mentioned that I need to use BVM heat shield on the inside or I will be ordering his fancy metal nozzles...
