RE: AR-6 Construction Thread
The temperature warmed up from 20 F this weekend to about 50 F today.
I took this opportunity to spray on the clear coat.
A fast hardener was used as the temperature was cold. I thinned out the clear coat using a fast reducer, so it would lay down easier in the cold temperature.
A light coat was applied over the surface. It was let to dry a few minutes and then more coats were applied until the surface was shiny.
I set the parts out of the way to dry.
