RCU Forums - View Single Post - Looking for a Beaver!!!
Old 09-15-2003 | 11:54 AM
Closterman
Default RE: Looking for a Beaver!!!
Just to add some comments about the MR Aerodesign Beaver. This aircraft was designed with original De Havilland drawing. So the shape is very accurate. Also, I think (i'm not sure), but, it is the only kit who have the 2 cowl (like the real one) with the scale air cooling exit.
I currently design the scale gear leg with fonctionnal rubber oleo and also the float.
The gear pickup are exactly the same that the real one and you will can change the aircraft configuration (sea or land) in less than a hour.
All control surface are scale with hinge position and location like the full scale Beaver.
The control rod and horn for the elevator and rudder are hidden in the fiberglass tail cone. The flap and aileron control rod are also at the same place than the real one.
If you seach for a very scale and easy to build Beaver, I think is't a very good choice !!
If you need more info about this plan and/or semi-kit, just go to my website or drop me an e-mail !!
