Problem programing JR 652
I need a step by step procedure to program the ailerons with two servos. I've converted this plane from one servo for the ailerons to a servo for each aileron and have been unable tosucessfullymix the the two channels. I have one of the servos plugged into Channel2 (aileron) and the otherplugged into channel 6 (flap). When I was using one servo on the ailerons I had 25% rudder slaved to the ailerons. Does this have to be disabled before I mix the two ailerons? If so tell me how to do that. By the way, that was through switch F-1.I would hope to mix the two aileron servos without aswitch. Any help with my problem will be appreciated.
