RE: 6' Beaver build
After a re re re read, I made a mistake. The plug or raw foam core does not get any primer paint! That would ruin it. Just sand it as smooth as possible, fiberglass it, and then you primer and fill the glassed core(plug) until it is the finish you desire. Then the gasoline trick. Please be careful! Don't bolw yourself up or burn down your house! Later
