RCU Forums - View Single Post - CA Problem
Thread: CA Problem
Old 09-15-2003 | 11:27 PM
Azcat59
Default RE: CA Problem
If all else fails, and you can't get it loose, you can use two aileron servos, one in each wing bay. Fairly easy to do and is a better quality system anyway. Then just cut off the vertical portion of the torque rods and don't use them at all. If they bind, cut them off with a Dremel cutting wheel where they enter the tube at the outboard end.
Good luck!
Clair
