RCU Forums - View Single Post - Someone mentioned warped wing
Old 02-04-2013 | 07:22 PM
rkcruit
Default RE: Someone mentioned warped wing
Hey Zor,
Aquestion re: my Sig 1/5 scale J-3 Cub, if you would be so kind.
I am in the process ofassembling the Cub'sfuselage and am concerned that I might have a very slight warp or twist in the body. I placed a straight edgeacross therear of the fuselage (where the horizontal stabilizer will attach) as well as one across the cabin where the wing will attach so I can eyeball the two straight edges from the rearand look for any misalignment. It definitly looks like the stabilizer, when attached, will be tilted to the right in reference to the wing. Now having said this, the fuselage has not been glued at this point, but is held together with clamps on the top and masking tape on the bottom. It might just be fine when everything is glued...but if not, I have a big problem since things can't be unglued. Any tips on ensuring that everything is totally square before taking that final glue step?? It is being built on a piece of glass.
Thanks in advance.
Robert
