RE: Marking servo leads
I use 1/4 inch yellow DuBro shrink tubing. Cut about 1/4" for each lead you want to label and slip them over the connector onto the wire. Use a fine tip permanent marker to mark the label, then heat. They will snug down tightly and are still very readable.
John S.
