RE: Need a little p.a.w. advice
Once you manage to get the backplate off, the rest is pretty easy to take appart and check too. If it is plain bearing, it could be binding between the crank and case. Some PAW engines also have a little too much play between the prop driver and crankcase, a few extra shims there will keep the rod from touching the backplate.
