RE: ParkZone Albatros build and fly
I tried 2650mah 40C batteries and they were difficult to load. Am going back to the 2250mah 40C. Found some weak spots in the Albatros The wheel plates break
at the hub. The wire axel that goes from wheel to wheel broke off at where a wire was welded to it. It appeared brittle. These problems happened on different days. The broken wheels also happened to a friend at my field. I am getting some good rolls using a momentary full deflection elevator down stick Inverted flight takes about one half down elevator The bottom of the bottom wing tips need some protection as they get hit a lot. I am getting 8 minutes plus flying time on the 2250's.
