RE: New Alpha 40 Prop Problem
Heres how the prop should be assembled. spinner back plate, prop, thrust washer, nut. spinner...the nut should have threads and so should the end of the crankshaft. tighten the nut by using a wrench, not a glow plug 4 way, until it hurts your hand from holding the prop
