RCU Forums - View Single Post - Eindecker EIII
Old 02-12-2013 | 04:46 AM
  #221
Horsepoweraviation's Avatar
Horsepoweraviation
My Feedback: (50)
Default RE: Eindecker EIII
ORIGINAL: Billy Clink
Hello Paul , You can feed a Chicken hawk Chickens and it still wont fly like it would if it ate hummingbirds ! you guys just keep building . I havent heard from Larry , are the flying wires functional or not on this plane , if not I can see why the fuse is built so heavy ! If they are fuctional , can the fuse be built lighter than you guys are doing ? Hell paul , i know what you build needs to be strong , due to the super charged nitrous powerd engine you have hid behind the dummy radial . I think you put the heavy aluminum cowl on it not just for looks but as a scatter shield like a dragster has in case of excessive RPM engine explosion ! HorsePower Aviation at its best ! just kidden ,, keep up the good work !
Clink,
The wires are not functional.............[X(][X(]
My Hummingbird has a DA 85 installed.....while this is not my normal power to weight ratio.....it should still pull the crap out of this plane[:-][:-]
I hope to see you at more events this year, we miss your.... weird off the wall,demented,perverted,paranoid,physco,immature,n ucklehead HUMOR!
Cheers,
HPA
