Ok, moving on.........
I reinforced the joint in the aileron trailing edge ...... and then I corrected my misplacement error by adding another bit of material so that the aileron rib would be properly positioned.
........looking around it seems that I have been bumped to the end of the line........Rhonda is staining/finishing a set of shelves......so I better be careful while the Poly dries.....and stay out of the way while the 2nd & 3rd coats go on.
I told her I was going out to do some sanding [X(][X(][X(] hahahaha
