ORIGINAL: SkyPilot101
How soon do you think Horizon will grow this up to a 15cc mill?
I hope if they do this that they design it to run higher rpm like the 10gx. To me the biggest drawback of the dle20 is it doesn't survive well at higher rpm, so a 15cc of about the same weight as the 10gx would be a good solution, especially if they had a better muffler system like a wrap around muffler such as the ones Jtec sells. The 10gx muffler is pretty huge for a lot of applications. And the bisson muffler they suggest is designed for side mounted engines. They need a muffler for inverted mounting.
Ed
