RE: New Rovan 5T Terminator
I did. There aren't a lot of metal to metal screws. They are all located around the engine. When I changed out the clutch parts I got to most of those and put on some loctite. And the bumper in the rear needs some help also. I would recommend you change out the servo saver for a Dark Soul servo saver. I had a problem with the stock one right out of the box. The rovan one is not the same as the HPI one. For the price you can't beat it. Did you order yours yet? What model did you order? What engine size?
