RCU Forums - View Single Post - jetibox mini
Thread: jetibox mini
Old 03-09-2013 | 11:26 AM
OhD
Default RE: jetibox mini
ORIGINAL: Rune
Hello
have anyone used this Jetibox mini??
I have a Futaba rx and connect it to the jetibox to get readout on the signal...but it only says that it waiting for input, I have a <font size=''2''>R7008SB rx (hv and sbus), I have been able to activate the esc but it dont seems that I get full power...or even better does some know what the signal width on the futaba is, top and bottom???
It seems that I have manage to connect to the esc and have ''control'' over that ...I have manage to change the direction off rotation.
And yes the throtel channel is ok ..checked with a servo so its working.
</font></p>
I don't have the mini but I have used the regular JetiBox. I found that it would not work on a Futaba receiver that was operating in High Rate. What I do is setup the transmitter using a "bench receiver", my original 14 ch 2.4GHz receiver. I set fixed end points of either 1.0 or 1.1 msec on the low end and 2.0 msec on the high end in the ESC. Then I set the transmitter throttle channel to slightly above 1.1 for idle and below 1.1 for arming. The throttle cut switch is used to arm and then idle. I set the transmitter throttle high end at 2.0 msec or slightly above.
Let me know if you still have trouble.
Jim O
