Should be a set of points & some kind of a cam on the crank or thrust washer that opens & closes the points when the prop is turned over . Also a arm on the timer to advance & retard the timing.Looks like you are missing some parts. Kind of a rare engine but condition is everything & will reallly drop the collector value due to any missing or broken parts . Good luck, Max H.
