RE: Albatros Dva
Balsa just isn't the same as hardwood or ply. A stain that works well for ply probably won't look at all the same on balsa. You might also find that, in the end, a lacquer or colored varnish or even a stain+polyurethane/polycrylic combination will give you the look you want.
