RE: Corsair F4U-1A Top Flite Giant ARF Modifications
I’m planning ahead before I fiberglas the fuselage. I need to hatch in order to turn on off my power for my ignition and for my receiver and to refuel the airplane as well as to refill the air for the retracts.
The first thing is to place some packing tape right over the balsa wood on the fuselage where the hatch will be. Then simply fiberglass this area and let it dry. The packing tape will act as a mold release an the dried fiberglass will simply pop off. This’ will become the actual little piece that I’ll use for the hatch after I fiberglass the fuselage.
Photos 2,3 and 4 show that I’m starting to fiberglass the horizontal stabilizer. As the elevators are already attached I first had to cut out the trim tabs first make some pieces for those, and then using SolorTex covering cover the elevators. Using masking tape to protect the elevators while I lay up the fiberglass.
Photos 5,6 and 7 show the pilot that I purchased from Best Pilots.com I’m going to use Pappy in my Corsair. I show him here sitting on the wing of my P-51 Mustang from AeroWorks. In the background you can see I’m using another Best Pilots inside my P-51. The AreoWorks P-51 is MonoKote as well and I’m fiberglassing this as well.
