RE: New Evolution 10cc gas engine
You can use tygon between the tank and carb but you have to be careful at each of the tygon joints as it tends to swell without using wire keepers to hold the tubing to any fittings and each of these joints can cause its own air leak. Don't use tygon at the muffler because it will melt the tubing within a very short time.
Pete
