ORIGINAL: Taurus Flyer
crigotti.
If you are planning to build the GL transmitter, have attention for two drawings of the article, the layout of the circuit board is the mirror image related to the components that are showed. For mounting of the components it would be better to make a new assembling plan to prevent making faults.
Seeing this fault it would be clever to check circuit diagrams related to lay-out plans too before start building.
Cees
Thanks. I saw the correction in GL. I couldn't post it because it was a .bmp file. I converted it and here is the correction notice. Good idea on checking the lay-out plans. I'll do a through check out of the documents.
