Oh Man lost another one to the dark side (RC)
Naw just kidding One thing I forgot, to convert you will likely not be able to use the cross venturi needle valve and will need a remote needle like the original LA version or perhaps could use an older type OS carb, The ones with the carb positioned needle valve assembly such as an old .40 or .46FP carb. Be aware that you will need to measure the carburator boss on the engine though if you do not use the OS-.46LA carb.
John
