ORIGINAL: Airplanes400
Actually, I see a lot of foamy pilots standing behind their plane for take-off quite a bit. And they always ask/advise others of the fact. All of whom always allow the guy to go on the runway.
It's called, COURTESY.
Moreover, If a guy wants to maiden his plane the same way, and request he have the sky to himself, others should allow this. At every field I flew at, this was also common practice. REGARDLESS OF THE COST OF THE PLANE !!!
Again, it's called, COURTESY.
No one should object to such requests. No one needs their ''flight-fix'' that much as to over-ride common courtesy to another.
I think that if anyone disagrees with this, they are r/c flight junkies!
You may need to go to R/C rehab !!
Here's a test. Below, there are two pictures.
If you look at the picture on the left BEFORE you look at the picture on the right, you are an r/c junkie in the purest form. You should sign yourself up for r/c rehab immediately.
If you even look at the picture on the left, you still need help.
Great post sir
joe
