RE: Recovering an ARF Kaos .40
If you are using Monokote you might look up using the Windex method to avoid bubbling (gassing) noted with this brand. That is,........ when you lay one layer over another layer of Monokote.,
Do a google search here in RCU on "Windex". If not using Monokote then disregard as other brands don't have the "gasssing" problem that Monokote does.
