RE: os 55ax mid range
Hi!
The problem isn't the engine it itself but the silencer lack of back pressure! Use the original OS silencer or reduce the exhaust outlet on the silencer you have.
No long running in time is needed any of our modern engines, they run and throttle just perfect from the moment you start them. The only thing you have to do is set the needles right
