RE: Arming switch - advice.
The 25lbs is how much force it should take to pull the metal connector off the wire it was crimped to. If you look at the data sheets for the metal connectors (15/30/45 all have separate data sheets), it has "Avg. Connection/Disconnect (lbf) 3 - low detent / 5 - high detent.
