RE: Cool
Yes, but a 3 blader with the same aspect ratio as a 2 blader loses more, whats more, if you swap from 2 to 3 blades the standard practice is to go down in diameter, lower aspect ratio effectively. Remember, air molecules do not get any smaller. With the same power, with less props, you get to have a longer prop, higher aspect ratio. Oh sure, you could have the same diameter prop and make it one wide blade, but they don't work quite as well due to the tip vortices covering a larger portion of the blade. I suppose it's a chicken and egg thing. Induced drag is what you are trying to get rid of, you do that by going to a more efficient wing, higher AR wings, as long as you can get on your airplane for the other aspects of the design, are what you go for. This is why the Corsair has those bent wings, trying to get as big a diameter prop on it while keeping it out of the dirt, and there is just a bunch of horsepower in that big ole Radial, more than when it started out. Happened on the Mustangs too, that's why with the Allisons you saw the skinny 3 bladders and on the later models with more power they went to those big ole paddle sized 4 bladders, gotta suck up the power.
Least that's what the videos and text said when I was in college, but, it was Tech college so I'm no aerodynamicists, they could've be dumbin things down fer us simple folk.
