Old 04-20-2013, 05:46 AM
hooleydog
My Feedback: (24)
Default RE: Anyone EXTENDED their CEN GST? Check out this Chassis Kit....
ORIGINAL: The Real Dogman
You DON'T need to reverse one of the servos you want them to rotate in the same direction so when they sit side by side and the servo horns point at each other one will push and other will pull.
And I meant power up the truck while assembled with linkages attached.
I did power up the truck first, and that's how I found out, that my 2 servos were going the direction, so I had to look for a fix, and reversing one fixed the problem, so it's ok as for these servos that I bought for my truck. They are way better that the Gst ones..
Mike..
