Old 04-20-2013, 10:12 AM
hooleydog
My Feedback: (24)
Default RE: Anyone EXTENDED their CEN GST? Check out this Chassis Kit....
ORIGINAL: The Real Dogman
Cool wider could be better, but keep in mind that the longer the wideners are the more stress you will put on the knuckles and arms which will cause more/faster wear! Not to mention easier breakage with the increased leverage longer wideners will create. But give it a try I am very curious to see if the suspension can take it.
oh and not trying to bust on ya but the measurement to determine the width of your vehicle is called Track Width not wheel base. Wheel base determines the length front to back, center line of front axle to the center line of rear axle. Just trying to help educate a little, sorry if it offends you.
I'm not affended at all, as for stress on the knuckles. I did hear that, though the c-hubs and knuckles on my truck are all aluminum, We'll see eh?? (Not sure if I should get the aluminum a-arms too)Though I would still do the conversion, but do it on a GST nemesis, as the truck has larger output bearings to cope with the higher torque of the big motor, and a steel front center dogbone (Not the Plastic one, as it might will break)
Mike..
