RCU Forums - View Single Post - Kingmotor baja problem
Old 04-22-2013, 08:30 AM
The Real Dogman
The Real Dogman's Avatar
Default RE: Kingmotor baja problem
I did not see clearance issues in your video, I saw wheels that are out of balance. If that's what you are asking about, then by judging the wear on the tires, this car has been run quite abit, which leads me to think that if the tires are just now showing signs of being out of balance, I would tend to think the foams got water or sand in them. That means removing the tires from the rims, clean out all sand and dirt and be sure the foams are dry. If the foams have disintegrated, then you will need to replace the foams.
You will need to remove front tires too
keep us updated of what you find when you remove the tires from the rims.
I hope this helps!!
