RE: check out my pipe idea, what you think
You may want to use some silicon tubing on it first to adjust the length before you weld it up for good. I personally don't like mufflers that stick in front of the cyl. because they can wreck the bolt holes in the exh casting boss. I have a lot of Supertigers like that from swapmeets. I don't like supporting pipes at the back either, so, ya, maybe
