Engine alloy parts
Looking at replacing stock plastic engine mount 6264 and 7039/1 with alloy parts.
I already bought 7039 but I must have knackered it as when I rotate the axle there is a lot of friction. I can no longer remove the bearings, they're stuck.
is it possible I damage the shape of the part? Should the bearings pop in easily enough on the alloy parts? For the plastic they're quite easy. I used the same bearings I did with the plastic part.
What part numbers are the alloy versions?
