ORIGINAL: Heli-NuBee
I found the problem with the Microsens on board glow system today. The problem was with a bad T connector. I guess I used too much heat when soldering the connector because plastic melted and kept the connector from making electrical contact. Eveything is working great now. I am very close to running the engine but should do some other minor small things like fuel proofing, rechecking control throws, tighten the covering and etc.
Best wishes and good safe flying.
Heli-NuBee (AKA Roger the radial rabbit)
Why use a glow driver when CDI will give you about 6% more power 20% better fuel economy, less oily mess, easier starting, lower reliable idle & overall better user friendlyness.
[youtube]http://www.youtube.com/watch?v=iERCMNum7XY[/youtube]
