ORIGINAL: gunradd
From what I understand to use flight conditions you need to set up the plane in glider mode. I tried this and gave up and just don't use conditions anymore. I agree a simple software update would fix this and I really wish they would.
For the flap mix. I guess you can just make new mixes for those. My problem is with only 5 mixes I used them all up and cant do anything for flaps
Bob B is da man and will get you straight when he sees this.
No, you do not need to be in glider mode to get conditions. Just need to set the surfaces as single, not group.
Flap mix is handled in both the camber flap, and the airbrake menues .... some of it is intuitive, and some of it is Martian....
Greg
