ORIGINAL: goirish
.... Do you put a separate switch so you can charge the battery. A switch like I would have on the side of the plane to charge the rx battery. .
Yes, at least that is what I did on the two airplanes that I do use glow drivers on and it is the same one you have. Used two Dubro switch/charge mounts in tandem on the side of the fuselage. Used these on my Hellcat and Corsair which I use for arrested landings.
John
