RE: Help with Shuttle ZX-A (Arf?) rotor head setup.
Wow, I hope you figured this out as this is an old post. The vertical guide pin is supposed to line up with the vertical slot in the aluminum hub that is 90 degrees to the jesus bolt. I hope you didn't try to fly it like that.
