ORIGINAL: Starkweather
The clod wheels have a little less offset that txt wheels. On full steering lock, the tires are almost touching the springs, so they are rubbing. I dont know what to do about this. What i want to do is get a set of txt wheels. Plastic ones, none of that aluminum business. Problem is, i cant find them ANYWHERE.
Any idea how i could widen this thing just a HAIR? Ive seen the wideners but i have no idea what to run for a stub axle. Guess ill find out later today how she drives on the kit wheels and tires
what other wheel options do i have? Im feeling frustrated and clueless now. Grrr.
You may have to use wideners. Juggernaut wheels would probably help, but those are even harder to find(except for the aluminum ones). Wideners often use the stock stub axles with barrel nuts. Those are like bolts, but are threaded on the inside to reach the threads of your stub axles.
Barrel nut.
