RCU Forums - View Single Post - GR130
Thread: GR130
Old 05-25-2013, 02:23 PM
  #62
athome
athome's Avatar
Default RE: GR130
Thank you Gerald
Wow how many turbines did you built?
I have only one gas pipe and the hole is exactly next to the line as you will see on the picture. But I have a small gap of 0.5mm in between of the cc and the plug/boss, so as I mentioned before, that is the Problem. Thank you for confirming!
I've found a longer glow plug (see the pic) and reassmbled the turbine and as soon as I pulled the coil arround 4mm (now it goes into the chamber) and entered a little higher voltage for the plug the turbine started again like a charm.
I have to fix this gap thing because I belive that the glowplug will oxidize/corrode after a few starts and that was the reason that it startet 5/6 times in the beginning without a problem.
What do you think about a kero start system? maybe that is the other option.
Regards Lukacs
ID:	1885443   Click image for larger version
ID:	1885444   Click image for larger version
