Help, truck revs itself.
Hi all,
I have a Maverick Blackout which I believe is almost identical to the Rampage MT.
After I put almost 1 tank of fuel through my truck (brand new), it started accelerating by itself. I tried adjusting the idle needle and low end setting on the carb and for a few seconds its fine and then just accelerates to top speed.
I checked the throttle linkage and that's fine, also it does not move when the truck accelerates by itself so it's def not the throttle causing it.
Any help will be greatly appreciated.
