tornando s30 engine problems
I am having a problems with my Tornado s30 and I need some help with some trouble shooting. I ran my Tornado through the break in process then ran it a couple times with no problems, it sat in my basement for about a month since I haven't had time to run it, I did put after run oil in it after every time I was done running it, went to run it the other day and the pull start seems like its stuck, took the glo plug out and tried to pull the starter and I couldn't pull it at all, tried turning the flywheel and that won't turn with or without the glo plug. Could the engine be ceased up already or is it something else i'm overlooking? Thanks for any help.
