RE: ZEnoah G-62
Thanks to all, especially Lightning fan. that thread was very interesting. I don't suppose Antique would do that for me? I'm going to go check several things but may not have time to run it until tomorrow. When I ran it on the test stand (about 3 weeks ago right after I got it) there was no gasket between the carb and the phenolic block, but I got a gasket with the properly slotted hole and put in there but that was after it would not start on the plane. The carb kit was also put in after it would not start on the plane. Incidentally, I just traded for a 90" P38 and I put OS 91 surpass on it but they will have to have on board glo to keep them running in idle. Weight = 18 lbs. what's yours weigh. I assume you got both G-62s running. Bud
