RCU Forums - View Single Post - Throttle servo HELP!
Old 06-07-2013, 06:03 AM
GT100
Default RE: Throttle servo HELP!
Does the steering still work when this happens? Does your truck have a failsafe installed? What you described will happen and the throttle will not respond but will go straight to break. If so, charge the battery fully and check again. If not then try changing the positions of the servo. Plug in the steering where the throttle would go and see if the steering servo does the same thing. If it does, then its a receiver issue and not servo. If not, then you have a bad servo. If you have a bad servo, dont feel bad. They just seem to go out on their own at times. I cant even say how many I've had go out like that.
