RE: E-Flite Super Cub 25e ARF
Looking at side two.. there will be a lot of glueing all at once as well as the challenge of using conopy glue at the same time on the rear window as well.
I started by repairing a couple things that need to be in place before the main gluing. An inside layer of the ply laminate side fuse side had lifted away though this piece was still attached to the main side at the rear of the break being not cracked all the way through, but close. My first post has a pic of this break in the bottom left pic. These are tht three vertical clamps. On the top, there was a thin ply facing that bordered the top window as well as what is used to to attach to the fuse side. these are the horiz clamps. You can see this piece on the opposite side. When they setup, I'll make and apply the 1/8" inside balsa doubler for this side and recut the holes. Once, thats in place then we'll be ready for the final attachment of the right side back in place.
