RCU Forums - View Single Post - NEW Tamiya Kits, Radio Gear and Brushless Combo
Old 06-14-2013, 08:55 AM
banzaihobby
Default NEW Tamiya Kits, Radio Gear and Brushless Combo
New Kits from Tamiya now in stock at Banzai Hobby!!!
Ferrari 458 Challenge - TA06
The Ferrari 458 Challenge is a circuit car which made its debut in 2009. Based on the 458 Italia, it is seen as the successor to the F430. Its 4,500cc displacement engine produces 570ps at 9,000rpm. For the final classy touch the interior of the original car was designed with input from 7-time Formula One World Champion Michael Schumacher. This exciting machine is now the subject featured on the Tamiya TA-06 4WD touring car chassis platform. The TA-06 chassis is a 4WD mid-level machine designed for easy assembly and high durability. The TA-06 has a high degree of tuning options to suit track conditions. It also features the ability to change suspension geometry to fine tune your car to your driving style.
Body Set Ferrari 458
This is a spare polycarbonate body parts set of the Ferrari 458 Challenge. It will fit on any Tamiya 190mm chassis such as the TT-01, TT-02, TA05, TA-06 or TRF racing machine.
Polycarbonate body
Injection molded light cases.
Stickers and window masking stickers included.
Side mirror parts are separately-molded in ABS plastic.
Compatible with TT-02, TA06, TB-03, TA05ver.II, TT-01 Type-E and TT-01 chassis machines.
Subaru BRZ - TT01D Type-E Drift Spec
This is a Drift-Spec Subaru BRZ. The Subaru BRZ body is mounted on the entry-level TT-01D Type E chassis platform which is the ideal platform for first time kit builders. The Drift Spec version comes with features, such as softer suspension and drift tires, which allow the car to drift with ease.
Toyota Land Cruiser 40 - CC01 Black Sp. Painted Body
The Toyota Land Cruiser 40 was a world-renowned 4WD vehicle that was produced for nearly 25 years. Tamiya's R/C offerings include a robust and rugged rock crawler platform (CR-01 chassis), a simple and fun to drive cross country platform (CC-01 chassis). It's now available with a new "street-
customized" color scheme which is again mounted on the tough CC-01 chassis with tires from the Toyota Tundra kit. The addition of these tires gives the R/C model a more custom look and feel.
Finespec 2.4GHz Radio System - w/Brushless ESC(TBLE-02S)
This is the Tamiya Finespec 2.4Ghz R/C radio system that comes bundled with a Tamiya Brushless ESC (electronic speed control) (TBLE-02 sensored type). This system is ideal for entry level users looking to complete their new R/C kit build
Finespec 2.4GHz 2-channel transmitter (TTU-08) x1
Finespec 2.4GHz 2-channel receiver (TRU-08) with antenna cable x1
TSU-03 servo with servo horn x1
TBLE-02S ESC x1
Optional trigger cover x1
About the TBLE-02S
Designed for use with the TBLM series of Tamiya Brushless Motors (Sensored Type).
Brake and neutral brake settings can be adjusted independently.
Features 3 protect ion systems against overheating, overloading and low voltage.
Also compatible with brushed motors (Normal Tamiya Type 540 and Tamiya Sport-Tuned Motors).
Dimensions: 45x34x25mm
Tamiya Brushless Motor and Sensored ESC 01 16T Combo
Not only usable for a long time is superior to maintainability, and was set with 01 16T brushless motor to be chosen as the race for the specified motor Tamiya, a brushless ESC TBLE-02S of the sensor with. TBLE-02S continuous maximum current 60A. Drip-proof type corresponding course brushless motor, also brush motor of 25T or more sports and tune. Basic specifications brake output setting, neutral brake output setting can be set up individually, the circuit with three types of protection temperature, over-current, low-voltage. Are you a fan, prices are attractive to RC you start now.
(ITEM 45058)
Basic Specifications
6.6 ~ 7.2V size 42 × 34 × 25mm Weight 50.8g Continuous current 60A maximum input voltage
Please come Join us on Facebook for Weekly Specials and Updates
Banzai Hobby Team
