ORIGINAL: Hobbsy
The Cline would definitely cure it and much easier than any other way.
Hobbsy,
How is the Cline system working in conjunction with the Saito engines? I'm asking as the cline is a demand type regulator while the Saito carbs normally see fuel pressure on HS needle? I've heard that some engines with oversize carbs, like Moki 2.1, won't work well with clines, too. And if I remenber correctly the installation instructions of the cline system refers to this matter suggesting to change to demand type carb if the original carb is an oversize carb.
Just curious..
